It is currently 30 Oct 2026, 21:47
Need help with an unknown led watch .[SOLVED]
iraklisk
Post02 Feb 2015, 18:52
can you help me please this is a SANYO ?
thanks
Re: Need help with an unknown led watch .IT'S SANYO?
Post02 Feb 2015, 22:05
If you look very closely at the crystal it has a faint makers mark stamped on it, I can't quite make it out from the photo but you might be able to see it clearer with a magnifying glass.
:scratch: Unitra? Dugena?
Post02 Feb 2015, 23:10
That´s for sure a Dugena, but the case has been used by Compuchron as well. Dugena is a German company that still exists today. The company name stands for Deutsche Uhrmacher Genossenschaft. The module is an early Sanyo.
iraklisk
Post02 Feb 2015, 23:22
bucko170 wrote:If you look very closely at the crystal it has a faint makers mark stamped on it, I can't quite make it out from the photo but you might be able to see it clearer with a magnifying glass.
thanks for the infos but no did't find something at the crystall but you have right after searching about Dugena Its the same logo as in my warch's bracelet
thanks once again !!!
iraklisk
Post02 Feb 2015, 23:26
SASM wrote:That´s for sure a Dugena, but the case has been used by Compuchron as well. Dugena is a German company that still exists today. The company name stands for Deutsche Uhrmacher Genossenschaft. The module is an early Sanyo.
thanks for the infos much aprecciate yes this is a Dugena
Post02 Feb 2015, 23:28
iraklisk wrote:thanks for the infos but no did't find something at the crystall .the logo at the bracellet? it's something like half SANYO logo
I did not spot the logo on the clasp - that is the logo of a Dugena, so like Hanno says Dugena for sure, mystery solved!
iraklisk
Post02 Feb 2015, 23:30
yes the mystery solved :-) Thanks !!!!!!!!!!!!!!!!!!!!!!!!!
Post02 Feb 2015, 23:32
The mark on the crystal is still faintly visible, I have highlighted it's position for you.
iraklisk
Post02 Feb 2015, 23:36
bucko170 wrote:The mark on the crystal is still faintly visible, I have highlighted it's position for you.
WHOA WHAT I FIND !! yes i see it write "DUGENA "
THANKS ONCE AGAIN
