It is currently 15 Sep 2026, 09:39
Batteries and Module for Breitling Navitimer 9106
heliolm
Post08 Apr 2016, 09:18
Hello Folks
Im just locking for a new led Module (frontier 2006) for a breitling navitimer 9106. the watch is unworn but has no function.
What Type of batteries Are the best for this watch.
I Hope to hear from a member.
Thanks patrick from Germany
Re: Batteries and Module for Breitling Navitimer 9106
Post21 Apr 2016, 00:31
heliolm wrote:Hello Folks
The module is so rare you will most probably never find a replacement. Afaik only the Sicura stop watch LED used the same module and the Sicura is even more rare than the Breitling.
Is the display damaged? If not then a repair would be possible.
Greetings from Kerpen!
Post22 Apr 2016, 18:32
I have seen that module in watches by other manufacturers, Helbros, Mercury for example, look out on eBay for watches with the same button configuration, then ask the seller to clarify if it is the correct module or not, just be aware that the module with the alarm feature has the same button configuration as the one with the Chrono feature, I think if you are patient one will turn up sooner or later..... it did for me.
Do not throw away the original module, if I remember correctly I had to swap the plastic carrier over as the one in the Breitling was slightly bigger those potential donors.
Good Luck
Post23 Apr 2016, 03:59
Old Joe has them I believe. He used to work for Frontier.
I bought one or two, as have others.
PM him !
wzy-hman
Post27 Jul 2016, 20:50
Unfortunately, Ole Joe had run out of them last time I asked!
