It is currently 23 Apr 2026, 14:26
Lambda missing segments
Post17 Sep 2018, 10:26
Hi guys,i'm not into led world (just have only 2 in working conditions) so i'm not a fixing leds expert.
I got this unknow Lambda led watch yesterday with two 386 dead battery inside... As i expected the watch doesn't work so i tried to clean the board as i usually do with LCDs....and the green-blue acid gone off without problem. The watch is now works in this way:
The quartz seems to be ok,i can see the seconds advancing...The wire bonds looks ok without missing or broken one.
Any help is welcome
Re: Lambda missing segments
Post18 Sep 2018, 09:48
Just a little update: no signs of life...seems to be dead.The only info i found is:
"When replacing batteries in this watch you must ensure that the battery contact plate is placed with the three points of contact on the 2 batteries and the quartz crystal otherwise the watch will not function."
