02 Mar 2007, 03:31
Hi there,
1 Best to strip the case down, crystal, pushers back plate and anything else that can be removed, i.e. not permantly fixed to the case.
2 Next, using progressively finer grit; I start with 400 than 600 then 1000 wet/dry sand paper until the dings and nicks are removed.
3 With my bench buffer I carefully buff until high polish, trying to keep the edges sharp. This of course tends to remove any of the gold plate left, however, the platers will chemically remove the existing gold in anycase.
4 a) Next is the step where you put your finish on, grained or polished etc. If graining then I use 200 grit garnet sanding sponge and grain in parallel strokes until the desired finish. Once plated the micro grains will show through the plate.
4 b) If a gloss finish is required make sure the final product is clear of blemishes and graining from the sand paper.
5 take it to the plating company, every town has one, if in doubt ask a local jeweller. My people only due the yellow gold plate, however there are people who can plate in other shades of gold, make sure you specify.
6 you will probably be asked if you want a satin finish or polished. I ask for polished and satinize it myself with Green Sheets of pot scrubber.
My plater is in Vancouver, British Columbia "ACME PLATING" but I am sure every large town will have one.
Geoff
