It is currently 15 Jan 2026, 03:50
Replacing glass
davefinic
Replacing glass
Post23 Aug 2007, 08:46
Unfortunatly the glass has fallen off my Novus Hex, but lukily ive still got it and its not damaged.
What should I use to remve the old glue and what type of glue should I use to refit it.
: Replacing glass
Post30 Aug 2007, 17:39
no replies yet? strange...
try acetone or if that won't help - heat up the case (without the module) and remove the glue with a scalpel or anything flat and similar (a Stanley knife?)
use any A+B transparent epoxy that is hard enough to keep the case watertight.
: Replacing glass
Post31 Aug 2007, 10:10
Also worth mentioning that the glue you apply will show through the glass once cured. (The glass used on Novus watches isn't very dark and the case + glue can be seen underneath). When you apply the glue use a very fine artists brush to paint the glue onto the underside of the glass, trying to stay as close to the edge as possible. Then do the same on the case, leave it for a couple of minutes then press together.
Azimuth is spot on with how to remove the stuff. I use a flat razor blade (disposable gillette or similar). Less chance of accidental scratching (although more chance of cutting your finger off).
davefinic
: Replacing glass
Post31 Aug 2007, 10:22
Thanks for the tips :-D
: Replacing glass
Post02 Sep 2007, 00:24
nice hint but that artist brush will have to be disposed once the glue cures or hopefully cleaned if you have a proper solvent for that particular glue. I try to keep costs as low as possible.
btw. the glue shouldn't be visible if you apply just the proper amount - there won't be any bubbles visible and the glue excess will not flow over the display edge on the case
: Replacing glass
Post04 Sep 2007, 10:11
I use Araldite A+B epoxy. Warm water and washing up liquid does the trick for me: I've been using the same brush for ages. I started using it on Pulsars as it's a good way to apply glue to the case without getting too much in there.
davefinic
Re: : Replacing glass
Post08 Sep 2007, 09:18
[quote="digibloke"]Also worth mentioning that the glue you apply will show through the glass once cured. (The glass used on Novus watches isn't very dark and the case + glue can be seen underneath). When you apply the glue use a very fine artists brush to paint the glue onto the underside of the glass, trying to stay as close to the edge as possible. Then do the same on the case, leave it for a couple of minutes then press together.
Great tip with the artists brush THANKS Digibloke.
Impleased that one of my everday wearers is now back in good working order. :-D
holly35
: Replacing glass
Post15 Oct 2007, 10:02
interesting to note that the novus hex models were manufactured in different qualities.i have seen the high polished hex crystal (crystal set open at the sides)in all s/s and a silver coloured base metal bezel version.also the large hex model comes with a non swiss and a swiss made case with a very attractive swirl pattern engraved under the glueing surface for the crystal.could this have been in response to the unsightly glue marks see on some versions.? strange that novus made better quality cases for the same watches.
they still remain my favourite led watches.if you look at their highest quality examples (quality varies with individual models)they are simply exquisite.this hex model with the swirl pattern, along with the swiss made,, "gem-cut" case model with its thick glass crystal ,all s/s construction and threaded "o" ring back plate seal makes it among the best quality led watches i have seen
: Replacing glass
Post15 Oct 2007, 16:59
azimuth_pl wrote:try acetone
That could be damaging to any logo that is not high-temperature baked on.
The "heat in oven method"(350 f.) won't disrupt most logos and loosens by both softening the epoxy and by the high rate of the case's expansion compared to the low rate of the glass's expansion. 8-)
Digibloke is quite correct - stay close to the edge, you only need a thin bead. I personally use pointed wodden toothpicks(same for mixing the glue in small batches, on a Post-it note), and gently paint using the end or edge of that. Isopropyl alcohol(90%+) for cleaning wet epoxy.
: Replacing glass
Post15 Oct 2007, 18:01
you're right Ed, but I guess you would be applying acetone to the bottom/opposite side of the crystal :)
btw. I have never come across a logo that would disappear after applying acetone. perhaps on plastic crystals?
Post15 Oct 2007, 21:36
azimuth_pl wrote:btw. I have never come across a logo that would disappear after applying acetone. perhaps on plastic crystals?
You didn't hear that one about the dodgy Pulsar screens?
You sleeping or what!! :-P
: Replacing glass
Post15 Oct 2007, 22:51
:lol: I need to wake up 8-)
Users browsing this forum: No registered users and 55 guests
