It is currently 07 Oct 2025, 15:24
Does anyone know anything about the Gillette LED watch
DaleS
Post14 Sep 2007, 15:57
This seems to be a very unusual LED watch. The back is signed Gillette, the vendor claims it is a wrist flick watch, and that it has a countdown timer and a stopwatch. Did they make LED watches with those features in the seventies?
DaleS
: Does anyone know anything about the Gillette LED watch
Post14 Sep 2007, 15:59
Sorry folks, I am having trouble getting the picture onto the site.
Dale
Post14 Sep 2007, 16:27
Yes they did and a fine piece of kit it is too considering what they usually go for. There's some info here...
http://www.ledwatches.net/photo-pages/gillette.htm
Majestyk
Post15 Sep 2007, 09:10
It's not a wrist flick per-say. You tilt it towards you and the time displays. You can turn the feature on or off.
Jeff
DaleS
Post27 Sep 2007, 16:45
Hello everyone,
I just received the Gillette watch. Wore it yesterday. The tilt-on feature is amazingly effective. When you tilt your wrist to just the right position and hold it for a second the display comes on. Shaking it or tilting any other way produces no result at all.
Do any of you know what the mechanics is of this very precise tilt switch? It has only been recently that digital levels have become accurate. I wonder what they did in the seventies.
Thanks in advance for your response.
Dale
Re: : Does anyone know anything about the Gillette LED watch
Post27 Sep 2007, 17:20
DaleS wrote:Do any of you know what the mechanics is of this very precise tilt switch?
Dale
Dale -yes, that is a nice feature, no shaking of the wrist. It is a simple mercury switch that bypasses the command button, set at 45 degrees to the circuit board, so when you have th wrist at the right spot, the watch shows time for the normal time period, same as the command button. The switch isn't responsive enough to shake twice and get the date. The Birks with this feature ARE sensitive enought that you can - tip once for time, tip back and down again for date, third time for continuous seconds. Drawback is you need to do it a fourth time to shut it off...or it will quickly deplete the batteries. And the Birks has no shut-off feature.
I have pulled those switches from a number of broken modules...not sure what I'll do with them, but they are too neat to trash. 8-)
Post27 Sep 2007, 19:02
retroleds wrote:...
Jeff/Majestyk could probably use them - ask him if he hasn't contacted you already ;-)
