It is currently 07 Oct 2025, 19:34
OT HP 45 / 55 timing circuits
Post22 Jan 2008, 03:52
Hi there,
I just restored an HP 45 and posted an article at the following url
http://www.hpmuseum.org/cgi-sys/cgiwrap ... 014#131014
My question is that I want to convert the timing circuit on the HP 45 into an accurate, quartz crystal based circuit. The instructions are posted at the HP museum site, however I am unable to find the appropriate 784 kHz quartz crystal.
Also I need a crystal for a P2 module I have which just died. I can't find sources for these on the web.
Anyone out there that can point me in the correct direction, especially if you live in the Vancouver, B.C., Canada area.
Cheers, Geoff
Re: OT HP 45 / 55 timing circuits
Post22 Jan 2008, 10:56
767Geoff wrote:My question is that I want to convert the timing circuit on the HP 45 into an accurate, quartz crystal based circuit. The instructions are posted at the HP museum site, however I am unable to find the appropriate 784 kHz quartz crystal.
A programmable oscillator could probably do this work. I don't know if there are one-time-programmable ones, else it would need a microcontroller attached to configure it on power-up.
