It is currently 30 Oct 2025, 18:09
Flashing first digit
Post26 Feb 2008, 11:21
Does anyone know what causes this to happen...
On a Quartzmatic watch I have, when I press the time command button the first digit flashes up the tens of minutes number. For example if its 2:15 then the digit before the 2 will flash a 1 for a fraction of a second. (In running seconds mode the first two digits show the tens of minutes like on a bulova driver).
It's working fine apart from this and I've had the display off and on again to check for a short so I know its not that.
It's probably a logic thing isn't it? :roll:
: Flashing first digit
Post26 Feb 2008, 15:01
Does the digit flash with normal brightness or brighter?
If brighter, it could be a "stuck" digit multiplexer.
If not, it's probably the logic that selects the digits to display depending on mode, a weak or defective transistor selecting the wrong digit at first. Anyway, this would both be chip-internal.
Post26 Feb 2008, 16:57
If anything I'd say it's not as bright - but it's only there for a tiny fraction of a second so it's difficult to say.
It's a pity as it's taken me a while to get it running but such is life...
Into the spares box with it and on to the next one ;-)
