funkyguyfromlondon wrote:hi
yes the gruen had a hughes module.but no pic
the imado.
is this (the pcb has a fine crack very near to the watch button contact.lefthand side) how much to repair if repairable?
thanks
regards
geoffrey
I have the same MOSTEK module with the same kind of crack on the right side. Actually the PCB has fine cracks in several places - must became a very brittle board as it aged. Caused flickering numbers, and watch worked only when temperature was warm. Finally the watch stopped working altogther.
Were you able to get this module fixed? Soldering fine copper wires across the joint would seem almost impossible to me. I'm going to try conductive paint, but would seem to be only a temporary non-durable "fix".
