It is currently 07 Oct 2025, 04:52
Differences between MkIII/IV modules.
Sully008
Post28 Nov 2008, 19:59
Okay, post whore here. :-D
Does anybody know the differences between a MkIII and a MkIV module in terms of features? I have a set of instructions for setting a Mk IV module (April '82), but I don't know if those will work with what I have. Actually, is there a way to tell by looking at the board if this is a MkIII or IV? This was an already open module so there was no serial #.
dot matrix
: Differences between MkIII/IV modules.
Post28 Nov 2008, 20:25
Here's a partial list I put together based on my own experience, I don't know how correct it is. The IV was a massive upgrade adding daylight savings time, improved accuracy, a second timezone, a stopwatch, and an inaudible, visible-only alarm. However, the IV did not have the AM/PM indicator of the III. The IV also used what it called a "jog" (like a doubleclick) for accessing or setting some of the new features. I'm not 100% certain, but I think the III didn't have this.
SYNCHRONAR 2100 (Mark III): Riehl Time Corporation
* Features: Hours:Minutes (24 hour; or 12 hour with AM/PM indicator which appears as a single LED element in the display);
* Date;
* Day:Seconds;
* Leap Year;
* Rate Adjustment 16 seconds per year increments (+/- 8 secs/year accuracy)
2 slide switches
SYNCHRONAR 2100 (Mark IV): Custom Circuits Corporation
* Features: Two time zones (Hours:Minutes;seconds) (24 hour or 12 hour - AM/PM indicator feature removed);
* Date;
* Day:Seconds;
* Leap Year;
* Rate Adjustment 8 seconds per year increments (+/- 4 secs/year accuracy);
* Automatic Daylight Savings Time Adjustment;
* Alarm;
* Stopwatch;
* Flashing timer
2 slide switches
Sully008
Post28 Nov 2008, 20:35
Thank you for that, liquid crystal. I guess one way to see if it's a Mk IV would be to try the different functions listed in the instructions. If it works, then it's a Mk IV, if not, a III.
Synchroserious
Post28 Nov 2008, 21:29
Yes, everything Liquid crystal said is correct.There is no Jog needed for MK III.The one other thing added to a MK IV is the delayed reaction (6 seconds)of setting to prevent accidental setting.
The simplest way to tell the difference between MK IV or MK III is the serial #. If it does not begin with #4 it is a MK III.If it is alreay open the MK III chip is rectanglar shape and the MK IV chip is square. ;-)
I will tell you that 99% of the opened up modules sold at ebay(not by me) as "MK 3/4" were MK III,s.
Sully008
Re: : Differences between MkIII/IV modules.
Post02 Dec 2008, 18:52
Howard,
Do you have instructions for setting a MkIII? I've got instructions for a I, II, and IV. Curiously, I've never seen Mk III instructions on the 'net. Just as an update, I've found another module that works, display is good on it as well. I'm going to attempt to replace the display on the other module that is missing a segment.
Synchroserious wrote:Yes, everything Liquid crystal said is correct.There is no Jog needed for MK III.The one other thing added to a MK IV is the delayed reaction (6 seconds)of setting to prevent accidental setting.
Keatah
Post20 Apr 2009, 19:59
I always like to say my re-built Mark IV *does* have an AM/PM indicator.
Right away / left toward
You've got 6 seconds to read the display :)
