It is currently 02 Nov 2025, 11:53
Fixing loose bracelet links on Pulsar Date/Command
Sully008
Post16 Dec 2008, 22:27
Hello all,
I've got a Date/Command bracelet where some of the links are "loose". They don't fit as tight as they used to, in fact, one link has a big gap between it and the link above it. Is there any way to tighten the connections between the links?
TIA,
Mike
: Fixing loose bracelet links on Pulsar Date/Command
Post17 Dec 2008, 01:00
There is, but it involves disassembling the bracelet down to the individual links, and bending and re-forming the little tabs that hold the link pins [and the wide "tongue" that extends from one link under the next]. It is not an easy task to seperate the "fixed" links [the ones that are not intended to be removed to size the bracelet]. I have found it is a 2-5 hour job [not counting any additional time spent in re-fininishing] to re-tighten a bracelet, but if done properly, the feel and appearance is just like when it left the factory.
Sully008
Re: : Fixing loose bracelet links on Pulsar Date/Command
Post17 Dec 2008, 06:28
Hi Bruce,
Thank you for that info. I'm not scared about taking things apart, this is a case with no module. It'll be a winter project. Has this been documented before? I haven't seen anything about removing the links (even the ones for resizing).
bruce wegmann wrote:There is, but it involves disassembling the bracelet down to the individual links, and bending and re-forming the little tabs that hold the link pins [and the wide "tongue" that extends from one link under the next]. It is not an easy task to seperate the "fixed" links [the ones that are not intended to be removed to size the bracelet]. I have found it is a 2-5 hour job [not counting any additional time spent in re-fininishing] to re-tighten a bracelet, but if done properly, the feel and appearance is just like when it left the factory.
Post17 Dec 2008, 17:51
Sully008 wrote:Hi Bruce,
http://www.thedigitalwatch.com/Archives ... ip_005.htm
An old busted up band is great to practice on. :-)
Sully008
Post17 Dec 2008, 21:12
[quote="retroleds"
An old busted up band is great to practice on. :-)[/quote]
Perfect. Thanks, Ed!
