If anyone’s interested in vintage electric clocks this old digital Data Time may be right up your street. It’s a fully mechanically timed panaplex display clock there is no integrated chips or timer electronics inside its all powered by a 1rpm synchronous motor, I bought it a good while ago with a display problem the single minutes digit was out (bottom right). When I started to investigate the problem it was clear there was a lot of work needed doing inside, repairs to tracks, the motor drive lever was broken, electrical contacts were missing on a gear, the timing was off on the gearing which was causing the digits to read wrong and the motor was making strange noises it looked like someone had been tinkering but thankfully they had not damaged anything so after many months of carefully rebuilding, adjusting and tweaking its finally back up and running as it should. During the re-building I’ve taken pictures of the different parts I worked on.
This picture shows the position of the motor and the amount of wires needed to power four seven segment displays note the big brass spacers between the two pcb's...
Next is the motor, I removed it and took it apart to see what was causing the noise, it was dry as a bone inside after a clean out and re-lub its as sweet as a nut...
This picture shows the tracks and pads where the gear contacts run and three thin wires which are used to keep the gears located for timing the display...
Next picture shows the gear train re-installed and the newly fabricated drive lever fitted to the motor shaft, note the three wires holding the gears steady this took a horrendous amount of time to set-up...
This pictures shows the panaplex displays these are filled with neon gas and glow orange when power is applied, the same principal as nixie tubes but a seven segment display…
Finally the finished article, the top display shows the hours bottom the minutes turning the button on the back anti-clockwise advances the time. I’am really pleased how good it turned out…:-D
I've looked all over the internet for information on this clock, nothing not even anything on the motor manufacturer I'd guess the date as early to mid 60's due to there not being any electronics inside, of course if someone knows different…
