It is currently 25 Jun 2026, 05:43
2-button CompuChron
timesofplenty
2-button CompuChron
Post08 Nov 2009, 00:09
Received a complete 1975 LED, I think the model is 23-11S as the bracelet and inside are marked as such. The watch works, but I'd like to know how to set it properly, and what the 2 buttons do. It appears that the watch shows time, date (1-31), PM dot, and seconds. I tried a few times to add pics with imageshack with no luck, so you can copy/paste the links below. Any info much appreciated, thanks. Scott
http://www.timesofplenty.com/compuchron.jpg
http://www.timesofplenty.com/compuchron1.jpg
LEDNutz
: 2-button CompuChron
Post24 Nov 2009, 22:30
From learning about these myself I found that the button at the 2 o'clock position is for time and seconds and the button at the 7o'clock position is for day and date (TU 24) or (11-24) if pressed a second time. There should also be a 3rd "Blind" button at the 3o'clock position that is used for setting each function. Hope this helps.
