It is currently 24 Oct 2026, 19:33
trafalgar module
steveh
trafalgar module
Post08 Dec 2009, 21:01
Hi Folks
I've a trafalgar, standard day date, that was working. I left it for a while and it now appears frozen, all the led's light up individually when I pop the batteries out but the buttons have no effect, any ideas? I had this watch bought for my 10th birthday, and its my favourite. If it comes to the worst does anyone have a spare module I can buy?
many thanks
Steve
: trafalgar module
Post08 Dec 2009, 22:40
Hi Steve,
Can you please post a picture of the watch and if possible a picture of the module (they are usually National Semi-Conductor N.S.C.inside), if I think what is wrong with it its a dead easy fix it sounds like it needs a new quartz crystal which are cheap and easy to replace so you won't need a new module plus it will keep time much better than before.
steveh
: trafalgar module
Post08 Dec 2009, 23:10
Hi Klippie
many thanks for reply. I'll put up a pic of it as asap, it is an ns module.
where about are you in scotland?
all best
Steve
steveh
: trafalgar module
Post09 Dec 2009, 00:25
Here's the pic:
Re: : trafalgar module
Post09 Dec 2009, 01:47
steveh wrote:I'll put up a pic of it as asap, it is an ns module.
Thats the one, its a very easy fix if your used to using a soldering iron if not I can do the repair for you if needed.
I'am over in Fife by the way.
steveh
: trafalgar module
Post09 Dec 2009, 12:46
Hi Klippie
that's kind of you. I'll nip own to maplin and buy a crystal. If I get stuck I'll let you know.
thanks again
Steve
steveh
: trafalgar module
Post09 Dec 2009, 15:44
HI klippie
it appears to be totally dead now, I've not yet done anything with the crystal, arghgh
: trafalgar module
Post09 Dec 2009, 19:27
Change the crystal over anyway they are only 50p it'll probably be just fine.
steveh
: trafalgar module
Post10 Dec 2009, 19:03
Hi Klippie
success! It now works fine. thanks for advice
all best
Steve
: trafalgar module
Post10 Dec 2009, 19:54
Excellent... :-D
