It is currently 19 Jan 2026, 08:08
Weight of Synchronar case materials
Post13 Feb 2010, 19:10
Zinc cases - 12.4-13 g. Center bar adds only .2 grams.
Stainless cases - 17.2-17.7 g.
Gold-filled - 18.3-18.5 g.
This is a result of weighing about 2 dozen cases.
I have no weights for solid gold or Titanium. I'm thinking the gold will be heavier that any of those above - unlike the situation with Pulsars, where a solid gold case actually weights less than a gold-filled case, due to hollowing of areas that are solidly filled on a gold-filled or stainless case. A Synchronar just doesn't have much room left for "hollowing out" the metal case.
: Weight of Synchronar case materials
Post14 Feb 2010, 02:34
Hi Ed.
Which ones were zinc ? I don't remember seeing these referred to before.
Don't tell me I've got another style to add to my collection :-)
Post14 Feb 2010, 02:40
They seem to have been primarily the cut-corner Sunwatch(no bar) case) and the Synchronar cut-corner. "Cut-corner" - angled, not the rounded corner.
A lot of those are mistakenly considered brushed stainless. Hence the weighing.
Post14 Feb 2010, 08:41
I assumed the flat corner models were SS.
If they're zinc, it might explain why most of them seem to be Sunwatch cases.......the centre bar could distort much more easily on a zinc case.
Post10 Mar 2010, 21:43
i have a flat-corner titanium synchronar top w/crossbar. it weighs 15.87 grams. peter
Post12 Mar 2010, 03:41
Hmm, that seems heavy for titanium. Guess it would be interesting to see what the weight ratio is to some other common meetals.
Post13 Mar 2010, 04:17
hmmm, maybe it is not titanium. it is a grayish titanium color. it does not scratch. i also thought it kind of heavy for titanium. peter :oops:
Post16 Aug 2010, 05:53
after now having worn this particular casetop for these last several months, it appears to be exhibiting the characteristics of s/s. i think it is a sandblasted top, giving it the grayish titanium look. it has flat corners and no slot in the rear for the setting magnet access. soooo, i guess it is s/s. :oops: peter
