It is currently 02 Jul 2026, 07:36
Compu Chron module
willholman
Compu Chron module
Post11 May 2010, 23:11
I've a Compu Chron that has no module. What sort of Hughes am I looking for and is there an alternative to turn this into a functioning watch?
: Compu Chron module
Post12 May 2010, 01:52
There are a lot of modules that will fit your Compu Chron(but a Hughes would be most "original equipment". Unless your CC has two setting buttons on the right side, in which case it is a whole 'nother thing. Sanyo module.
willholman
Post12 May 2010, 09:23
Thanks Ed. I'll look out for a Sanyo module then. I'll try to put a pic of it up later - but it only has one setting button.
Post12 May 2010, 12:30
Re-read my post - you DO NOT need the Sanyo module. I was just mentioning the possibility, "Unless your CC has two setting buttons...".
willholman
Post12 May 2010, 12:40
Oh. I thought you mentioned the Sanyo module as a cheaper alternative to the Hughes, rather than the one I needed if it had two setting buttons.
Which Hughes module do I need? How can I identify it?
Post12 May 2010, 18:46
willhomlam, if you can post a picture of your watch, or better yet with the module exposed, then our members can identify what you need and help you with an answer.
willholman
Post12 May 2010, 19:43
Hi. Ed's sorted me out with a Hughes 25mm module now but it's similar to this one. Hopefully there's a pic here!
Uploaded with ImageShack.us
willholman
Post12 May 2010, 22:21
Just out of interest; which other modules will fit this watch?
