Good news!  7 of 12 replacement modules work, much thanks to Fred at Surplus Shed for sending them to me.  2 of the remaining 5 do "function", but some LED segments do not light up.  The ones that work still came with small varying degrees of green colored corrosion on the battery side of the modules from 30+ old Union Carbide batteries (size 392 -- SR41?).  The functioning modules light up with LED segments made up of tiny dots, very cool!  Attached is a picture of the three *NON* functioning modules.  Well, the one in the middle works, but some of the LED segments don't light up.  The one on the far left is the worst of the three and is an example of what I initially received from Surplus Shed.  Can anyone, identify the manufacturer of these modules?  The quartz crystals have NDK stamped on them (Japan?).  For the CHEAP price SS is selling them for, I encourage you to buy some of these modules, if you want/need the smaller 20mm size for ladies sized watch cases.  I'm sure Fred will send the best one's out first, so your results may vary.
