Speed settings on a MK2 4 reed.
egomon
: Speed settings on a MK2 4 reed.
Post20 Dec 2010, 12:21
Thanks for the reply. Will change the qc today and lets see what will happend then.
Egon
egomon
Post29 Jan 2011, 20:12
QC replacement did the trick.
Thank you
Re: : Speed settings on a MK2 4 reed.
Post29 Jan 2011, 20:55
egomon
Post29 Jan 2011, 21:51
Hi Jeff. I use ordinary tuning fork qc.
I read somewhere here in this forum taht somone had a problem in bright sun light with new tuning fork qc. (module shot down or something) but I don't have this probelm with my modules.
Egon
Post30 Jan 2011, 01:45
egomon: probably because you don't have any sun in Finland right now. :lol: :lol: . actually, jeff and i have discussed this phenomena and not come to a real concete conclusion as to what exactly is the problem. it is obviously something not right in the charging system because as a rule it is not a problem. this is more than likely why these particular watches were returned to riehl to begin with. i have a few that have this problem, but for the time being just set them aside. they work fine if they don't get an excessive charge. i think jeff said that the qc shuts down because the voltage is too high. [at least i think that is what he said.] i have tried changing the qc's, but it doesn't seem to help. maybe it has something to do with the 2 resistors in the charging circuit. what do you think jeff? i was going to call you on that but never got around to it. maybe now is the time to address that. peter
dbmurphy
Post02 Feb 2011, 04:21
My mkIII
PS - PLEASE what is the default crystal setting? I changed min by accident, and forgot. I don't feel like waiting for it to fail AGAIN to have the setting restored to the default :-P
Best Regards,
Dennis
Post02 Feb 2011, 06:33
dennis, not sure what you mean by default setting. if you are referring to the speed setting the 2 mkIV"s i have are between 600&700. from there it is trial and error altho' i think each number increment is 8'secs/yr + or -. i think there is a copy of the instr on the photo gallery. peter
dbmurphy
Post02 Feb 2011, 16:35
Yes I am referring to the speed. It is something like 1314, when the watch powers up, but now I have been adjusting it for the last 6 months or so, because it is running too fast.
The reason I ask, it that it was SPOT ON with the default.
Oh and sorry but it is a mk III
Post02 Feb 2011, 18:47
i think the settings for the MkIII/IV are probably the same. what # are you showing now? 1314 sounds mighty fast to me. change it down to 700 and see what happens. peter
dbmurphy
Post02 Feb 2011, 18:53
Done - :) let's see how we go from there
Post23 Feb 2011, 03:18
db, how is the speed on your synchronar? did the lower # slow it down? :?: peter
dbmurphy
Post23 Feb 2011, 05:05
Yes !!!
I changed the value down to 1320 and it is still gaining about 10 seconds a week, but MUCH better, and I am zero-ing in thanks !!!!
Post23 Feb 2011, 06:46
Dennis, it just dawned on me, but i think you are pushing the left slider back to see your speed reading?? the display you see is 1320? if so the 1 is the leap year setting and the speed reading is 320. i have a mkIII booklet and that is what the left back slider shows. in reality you are in the wrong year of the leap yr setting. it should be showing a 3 since we are in the 3rd year of the cycle. you should be showing a 3320. ;-) ;-) peter
dbmurphy
Post24 Feb 2011, 01:59
OMG you are right :eek: !!!
I feel kinda' dumb now :mrgreen: LOL but THANKS very much.
Thanks Peter,
Dennis
Previous
