It is currently 07 Oct 2025, 04:53
who has english manual for SASM80 module
prasarn
Post16 Mar 2011, 12:31
i just got mk3 sasm80 module but very confuse to setting day&date
: who has english manual for SASM80 module
Post16 Mar 2011, 17:04
The SASM80 manual can be downloaded from www.strikesandspares.com Click "New Modules", then "Riehl" and then "Manual". Because of server problems (I also couldn´t receive emails for 1 1/2 days) there might have been also a problem with the pdfs. I´ve tried it a few minutes ago - the link is OK.
prasarn
Post17 Mar 2011, 05:23
i got it now many thanks.how long does it take to full charge the watch i experince low brightness when i hold slide for a while it dim to low light
Re: who has english manual for SASM80 module
Post17 Mar 2011, 09:43
prasarn wrote:i just got mk3 sasm80 module but very confuse to setting day&date
I am wondering, the SASM80 date should set in the same way the time is set. Again it should work like every Mark III movement.
Regarding the solar cell: This is an original cell and the charging circuit is also more or less the same. So you can take the original values as a reference. I´ve also improved a few things, f.e. the diode has been changed against a type with a much better forward voltage which is between 0.28 to 0.33 Volts.
prasarn
Post17 Mar 2011, 10:06
may be first when i got it does not full charge so it does not work as it should but it work now,by the way noon sun or evening sun is better? and if i use 60 w incandescent how many hour could to get full charge.
Post17 Mar 2011, 10:11
The best time to charge your watch is between 11-15h.
...At the moment, when I take a look out of the window there seems to be no difference if I would charge the watch now or by night...
prasarn
Post17 Mar 2011, 10:16
after full charge how last the watch or when i will charge again,have any feature battery indication?
