So,
When you're looking through Ebay and spot some fool who's just purchased those dog-looking wrecked LCDs somewhat optimistically - well it might just be me......
I received my two weekend won Broken Tissot LCDs today. From reading on this forum and elsewhere I think they are the Casiotron / Hamilton / Tissot 1976-1977 ones. Both with rough cases that I can refinish nicely, one with broken glass, one missing its original strap and both unashamedly DEAD. I opened them up and one had a nice clean looking Casio branded movement housed in green plastic. I'll post pictures of that one when I've had time to dig inside a little. But the other one looked, um, molested. And a bit grotty. But they are damn fine looking watches. So here it is, Patient A in pictures -
There's a scratch on the front layer of the display. It looks like it is the polariser and printed with the silk screen so I elect to leave it as is.
The gold plating on the battery terminal is delaminating and will have to be removed to prevent any floating flakes becoming Short Circuit hazards.
You can see that the flexi connector has been fiddled with, not refitted properly with one connection missing. Under a loupe it looks pretty bad. The kapton / copper / top have all delaminated and it has been refitted sans kapton. I would describe it generously as 'falling apart'
The front of three PCBs comes away freely as it was designed to -
The remaining two PCBs open out following the removal of four screw - one has a Vbat+ contact under it, another on the long stand-off is longer than the others - don't mix them up later.....
The front display PCB has a clamp holding the sandwich together. Uh oh this looks bowed - crack to the back of the Liquid Crystal element from being screwed down without being lined up properly....
Also, one of the conductive rubber contact strips is shorter than the other and doesn't cover the whole row of contacts on the glass. Damn. But wait....the contacts at one end of each row is connected together by a track-via-track on the underlying PCB (see two photos up....) so its not required and I guess as designed. This seems a bit silly to me - if you refit the rubber strip at the wrong end of the slot then you're U/S.
The remaining two PCBs can be seperated once the flexi connector clamp is removed (the clamp takes the unconnected/broken flexi track with it....) -
When I opened the case up a single strand of wire about 1cm long fell away. Not surprising to have some rubbish in there given the state of the flexi and the display reassembly. Whilst having a really good inspection of the remains I spotted a stray wire coming off a screwed on component next to the battery terminal. I guess this is where that stray piece came from -
There has to be some explanation for this. A nicely designed and assembled module like this has screw-fit components for a reason. I presume that it is select-on test capacitor to trim the quartz to a within the range of the variable capacitor. It is connected to the crystal but I guess that someone saw it next to the battery and perhaps took it for a blown fuse and shorted it out with wire (its a cap so measures DC open circuit...)
Now the diagnosis is complete we are ready to operate. My first fix just reinstated the single missing link on the flexi and cleaned up the switch contacts which seem to be plated onto the outside circumference of the board and got rid off all of that loose gold from the Batt- terminal -
I properly reassembled the front display and carefully refitted the remaining flexi contacts onto their respective pads -
But still dead. So then I changed the Xtal. Still dead. So then I faced reality and figured that the flaky flexi had to go, chopped it and set about reinstating the connections using some kynar. Of course there were lots of handy vias and pads to use well away from the terminals on the top PCB but on the bottom one I had to solder right onto the IC pads. Fortunately I had some top line equipment that was more than up to the job.
The patient on the operating table -
Whole again-
The scars-
Reassembled and now it .... still doesn't work. But the backlight does and wait was that a flicker I saw? Push. Flicker. Push. Flicker. Looks encouraging. There now seems to be a problem with the contacts on the flexi rubber strips. I tinned the pads on the PCB to provide some slightly raised bumps. A few segments there now when recased and I can get more by pushing directly on the glass over the rubber strips on the front face when out of the case. So I stacked some grey PVC tape into strips as adhesive spacers to safely apply a little pressure when cased and attached in the relevant places -
And so she sings once more -
Just need to rub her down with wet and dry, bit of Tcut, bit of Silvo, maybe some Scaryum on her face. But first I need to go and tickle her younger sister.....
MP.
Whole again-
The scars-
MP.
