It is currently 30 Oct 2025, 22:02
Bulova drivers crystal remuval
egomon
Post09 Jan 2012, 12:43
Hi. next project what I have on the table is Bulova Computron N7, and I have new case for it and band and module. I need to remove from one old case a crystal for the new case. So my question is next:
Is the crystal removal from the Bulova drivers the same as with Pulsars? Pre-heated oven 175 C for 20- 30 minutes and gentile push and then the crystal will pop out or is there some other means to get it out safely?
Regards
Egon
Sully008
Re: Bulova drivers crystal remuval
Post09 Jan 2012, 17:19
Hi Egon,
In my experience with 2 Bulova Drivers cases were they just popped out with a little pressure from behind. I didn't need to heat them in an oven first. The glue holding them in wasn't very strong. But the heating method is probably what I would've done next if they didn't come out right away.
egomon wrote:Hi. next project what I have on the table is Bulova Computron N7, and I have new case for it and band and module. I need to remove from one old case a crystal for the new case. So my question is next:
Regards
Egon
egomon
Post09 Jan 2012, 21:01
Thank you for the reply.
The crystal swap was successful and it was very easy. All it take was oven pre-heated to 175 C and 15 minutes in it and the crystal came off very easy.
Thank you
