It is currently 15 Sep 2026, 09:56
Search Function
Please write what you like me to improve or what´s currently not working properly.
Search Function
Post28 Jan 2012, 13:32
Hi Hanno.
The search function doesn't seem to be working properly.
For example if you search on 'synchronar', only one result is returned.
The posts are all there. You can find them by clicking on 'all posts by' 'clockace' or myself etc.
It seems to be the same for any search I do. Very few or zero results are returned.
Perhaps I'm doing something wrong ?
Re: Search Function
Post28 Jan 2012, 17:01
At the moment I am creating a new search index to solve this problem. It might take two hours.
BTW the module arrived today. Hanno
Re: Search Function
Post29 Jan 2012, 04:21
Thanks Hanno.
'Synchronar' now returns plenty of posts.
Not sure if you're still working on it, but if you search on 0624, only one post is returned. I know ther are plenty more that should be found.
Re: Search Function
Post30 Jan 2012, 02:04
Hm, tried via google:
search dwf.nu: 253 results
search strikesandspares.net: 4 results
Re: Search Function
Post30 Jan 2012, 19:15
I am still working on that topic. I will do the next step on friday night. Maybe the search function will be disabled for a few hours.
Hanno.
Re: Search Function
Post16 Feb 2012, 10:17
Solved! The search index has been updated! Hanno
retrowrist
Re: Search Function
Post16 Feb 2012, 20:40
Hanno,
Were any of the threads removed during the server transition? Just curious.
- Patrick
Re: Search Function
Post16 Feb 2012, 22:29
SASM wrote:Solved! The search index has been updated! Hanno
Sure? Searching for 0624 just returned "No posts were found because the word 0624 is not contained in any post."
Re: Search Function
Post22 Feb 2012, 08:34
Please try again. Sometimes my provider has to make certain settings which takes a bit. However I am always working on board improvements and the search function seems to work since 07:00h today. Please report further problems with the search function right here. By the way no posts have been lost, deleted or assigned to a wrong category. There have been no real board software updates for more or less 10 years. That´s neither good nor bad because the system has been running so far. But this means 10 times the work right now.
Hanno ~:( ~:( ~:( ~:(
Re: Search Function
Post22 Feb 2012, 19:19
SASM wrote:Please try again
Done: "Search found 108 matches", this thread included - much better :-D
Return to New Forum: Problems and Proposals
