Hello Everyone,
I was able to finally open the case on my Seiko 0662-5009 thanks to Adam and his generosity to send me illustrations that guided me in the right direction , but I still have a problem with it blinking and flashing in the second segments. Can anyone help me with this issue? I am sorry to bother you guys, but a couple of people have commented on this issue in my last thread about the problems this watch is giving me, and gave me some sage advice...
**PROBLEM
1) The second segments of the watch flash "on and off" noticeably regardless if the stem is pulled out to the "set" mode or not. So the seconds are constantly flashing noticeably.
2) When the watch is in normal use, if I use the "light" button, the seconds "reset" to "00."
**SOLUTION
1) Change battery and the flashing second segments will return to normal.
2) Do a proper cleaning (battery contacts and button pushers), and the seconds will return to normal.
A couple of things here...I did try cleaning the contacts with a CLR solution mix with distilled water where there was contact with the pushers and the battery well, but that did not resolve the issue. Also, I tried a new battery, and that did not resolve the issue as well. Is this module just broke!?
NOTE: I did NOT pull the LCD from it's slot, and clean it, so if this is something I should try, maybe it is an oversight on my part.
also, I discovered that this crystal was made of plastic, not glass.
Anyway, Thank you all for looking, and if there is something I can do to resolve this issue with a flashing second segments, it would be grand.
- Patrick
**PROBLEM
**SOLUTION
- Patrick
 I use "Brasso copper polish" and an old cotton towel. Apply some polish on the towel and polish the crystal in circular motions. Apply some pressure, but be careful, don't push too firmly.
