It is currently 08 Oct 2025, 00:09
Litronix module wanted
Pauly
Post26 Apr 2012, 21:59
HI everyone. Does anybody have a close up of this module which I believe is a litronix from a 70s Trafalgar LED watch? Some of the fine wire bonds are off the board and I am not sure where they go. Looks like a pretty intricate job so am not sure if it is beyond my very limited skills.
Re: Litronix module
Post26 Apr 2012, 22:21
If the module has broken or missing wire bonds it will be easier and more cost effective to just replace the module, it is not such a rare module and if you post up the size of the module and the position of the contacts someone might just have a spare to sell or at least be able to point you in the right direction to one.
Pauly
Re: Litronix module
Post26 Apr 2012, 22:36
Cheers. The module looks to be 29mm diameter with a depth of about 7mm and the pin positions are at 2 oclock and 8 oclock with the set pin at 3 oclock, if that makes any sense. Sorry about the bad picture before. I will have to work on my posting skills too.
Pauly
Re: Litronix module
Post12 Jun 2012, 22:26
Hi everyone. Just wanted to ask again if anybody has got one of these working modules for sale. Many thanks.
Phasar66
Re: Litronix module wanted
Post14 Jun 2012, 06:40
This watch had a module just like yours, a Litronix, very fragile, I crack it with the wrong batteries. If mi memory
is good it only had time only, no date. I replace it with a different module that fit the watch with date and seconds.
I hardly use it. Is for sale, with case include. Check pushers position.
Pauly
Post14 Jun 2012, 20:11
Hi Phasar66 and thanks for the reply. Unfortunately the buttons on my watch are in a different position. They are at the 2 o clock and 8 o clock positions with the set button at the 3 o clock position. Thanks again Phasar and hopefully somebody will have one somewhere.
Phasar66
Post14 Jun 2012, 21:17
Looks like the same position of the Hughes Aircraft 29mm also 7mm thick , even better.
Here is a picture of a non worker.
Pauly
Post14 Jun 2012, 23:17
Yes it looks like it could fit. Thanks for the information Phasar you have been a great help.
