It is currently 02 Nov 2025, 08:26
Seiko A128 fault
Ade51
Seiko A128 fault
Post08 Aug 2012, 14:11
Well I thought I would stray from my usual LED purchases and dabble in a few LCDs. Picked up this Seiko for a few pounds which was a non runner. Cleaning contacts and putting in new batteries (which have been in for a week now) have produced this:
It's running fine but the digits are washed out. Would this be the polariser and is it an easy fix?
Re: Seiko A128 fault
Post08 Aug 2012, 18:04
good question...i personnaly don't think that you can fix it. Its not the polarisers but i've read that some had better contrast after renewing them.
I think the problem is no liquid cristals enough left between the panels. Don't ask me why!! maybe a leakage, maybe from the sun.
i hope others have better idea's :-D
Post08 Aug 2012, 18:50
I think this is the polarizers. Hopefully the front one only but quite possibly the back as well. I have had excellent results replacing them(usually just the front). You could even try just placing one over the top of the existing polarizer to see if it made a difference.
Ade51
Post08 Aug 2012, 19:08
Thanks Kasper and Adam for your help. Now I'm a newbie with LCDs but keen to have a go. Would this be suitable as a ploarising film or would I need something more specific?
http://www.ebay.co.uk/itm/Smart-Polaris ... 4605baec6f
Post08 Aug 2012, 19:18
lets hope it works..keep me informed will you!
i bought mine here...thicknness 0.22 ..i hope to find even thinner next time.
http://www.3dlens.com/shop/lcdpolarizer.php
how to do it!
http://mygshock.com/wiki/How_to_convert ... ve_display
Post08 Aug 2012, 20:45
Nice trick with the polarised film switch to make a negative display, would this mask out an area of bleed if the bleed is not effecting the digits?
Post08 Aug 2012, 20:51
I havent tried but would it make the bleed reversed out too?
Post08 Aug 2012, 21:20
no it will not work...tried it :-(
Ade51
Post08 Aug 2012, 22:24
kasper wrote:lets hope it works..keep me informed will you!
how to do it!
Thanks Kasper. I'll have a go later this month and post the results.
Ade51
Post19 Aug 2012, 17:34
Thanks guys - new polariser fitted and all is well ........
albertofenini
Post28 Oct 2012, 20:24
Congratulations !!
Very nice done.
I have few LCD that I would like to treat this way in order to get a better contrast.
Can you please tell me if you have used the polarizer that Kasper had suggested,
and how difficult is the process ?
Thanks again Alberto
Ade51
Post31 Oct 2012, 13:35
Hi, Yes I have now purchased the polarisers recommended by Kasper. I didn't take the old polariser off - all I did was to place a cut out piece over the existing one and it has worked fine. It is really easy - just remove the module and cut out a strip the same size as the existing polariser and remove the backing film and place on the module. I've done 2 now and the 2nd one took less than 10 minutes.
albertofenini
Post31 Oct 2012, 14:21
Thank you so much for your reply,
sorry for not asking before, did you go the anti glare or not ?
thanks again Alberto
Ade51
Post02 Nov 2012, 23:38
The first one I used a normal polariser which is in the photo and the 2nd was an anti- glare but I struggle to see the difference on the modules.
albertofenini
Post10 Nov 2012, 12:21
Thank you very much for help, I have purchased both types and I will post
the results once I will have received the items, thanks again !
Alberto
Ade51
Post10 Nov 2012, 14:27
That's great - would love to see before and after pictures
albertofenini
Post24 Nov 2012, 18:44
Ade51,
looks like i'm not good at it ....
I have opened a thread
http://www.newdwf.com/viewtopic.php?f=64&t=5941
any advice will be very welcome !
