It is currently 02 Nov 2025, 04:53
My solution to a weak Pulsar P2 button
Phasar66
Post12 Aug 2012, 01:57
I bought this nice non working P2 date the other day because I had a beat up Hamilton with a working module.
I refinish the watch and procced to the module transplant, the time command button refused to work, the reed was good
I knew because switching the module 180 degrees to the date command got it working. I try to adjust the time reed with no luck,
I mean I move that thing everywhere and nothing, I knew reeds and magnets are match but finding a matching reed for this watch
and testing will be too much work, and replacing a bad button is no fun, what to do. after a week I came with this idea,what if I can assit the button with another tiny magnet, just to increase the magnetic field, I played with a small magnet from the outside of the wath so when pressing the button the time will display, it works. Now lets get the magnet inside the case, I filled the magnet to a rectangular shape so not to interfere with anything inside, I temporarilly intalled the magnet with double sided tape
untill I found the sweet spot, then I used epoxy to fix it there permanent, SUCCESS!!. It work like a dream now, you can even tweek the position of the magnet to your taste. Enjoy the pictures.[/size][/color][/size][/size]
Re: My solution to a weak Pulsar P2 button
Post12 Aug 2012, 09:37
Fantastic! I'm very glad that your Date II works well now. It seems that this can be the solution for all the people who have a Pulsar with a non working button!
Ade51
Post12 Aug 2012, 15:11
This sounds like a good idea - good alternative than trying to taking the button apart. Now have you got a simple way to replace a quartz crystal extal :-D
Post12 Aug 2012, 15:39
Maybe you can use your magical Wand and say "reparo". :-D
Btw.. Clever and easy solution.
Phasar66
Post13 Aug 2012, 06:36
Ade51 wrote:This sounds like a good idea - good alternative than trying to taking the button apart. Now have you got a simple way to replace a quartz crystal extal :-D
Quartz crystal, I have done 2 so far with success, Is not hard if you have a good soldering iron, you know the ones you can adjust the temperature. this make it easy because you can do it quick with out overheating . I have the Hakko brand and is very good. if the module is not working or only one digit lights, I shake the module and listen for a rattle, a sign that the crystal inside the canister has separated, The crystal replacement not always will solve the problem, sometimes the problem is downstream on the oscillator circuit and an oscillator chip will do it. I think the Xtal replacement is the easiest to do and is very rewarding. I you haven't you should try it.
Ade51
Post13 Aug 2012, 18:35
Thanks Phaser66 - I will. I've found a lowish (20w) wattage iron with a 1mm fine tip. I do have a few modules where only 1 digit lights up so maybe a new QC could fix some of them. Its a bit daunting though as looking at some of them (particulary a Pulsar mens dress watch module I have) its difficult to see where the ends of the QC solder onto the board.
Are there any links to 'how to' guides anyone knows about - I've had a look but haven't found one that is detailed.
Post14 Aug 2012, 18:34
Ade51 wrote: Its a bit daunting though as looking at some of them (particulary a Pulsar mens dress watch module I have) its difficult to see where the ends of the QC solder onto the board.
Don't try to solder to the board, you will lift the traces and ruin it. Rather, look at the crystal, it is actually soldered into a metal tab that has two holes in the end of it - the tab is connected to the board. If you use a thin clamp (or two, as I show here,,,module balanced on my thumbnail), you can get it between the board and the point where the crystal is soldered. I personally would suggest an 15-20w iron that is not temperature controlled. Temperature controlled irons are good for specific tasks, but the lag when they are cycled down can leave you glued to a spot on something a little larger, while you wait for the iron to heat up. Really bad for desoldering with desoldering wick - the wick will suck the life out of a smaller temp-controlled iron and you will kill the circuit while you wait for the iron to actually melt the solder. Myabe my real hatred for temp-controlled irons came during my stained glass hobby.....nothing like smoothly running a line of the solder for finishing a long section and having the iron lock up. nNyway, yeah, learn to swap crystals.
Ade51
Post15 Aug 2012, 01:00
Thanks Ed, I've got my iron and will have a go next week. I have an NSC module from a trafalgar that only shows 1 digit and looks simple enough. I'll have a go with this before I start on the Pulsar.
Ade51
Post18 Aug 2012, 15:45
Had a go at replacing a NSC QC and......success... see post about Watch Job Lots - a nice Novus brought back to life :-D . The NSC module was a simple place to start but where do I start with a Pulasr Mens Dress Module - I can't see where the QC is soldered onto the module. Does the module split in 2 to see the board easier?
Return to Mechanical
