It is currently 29 Jun 2026, 17:31
Restoration of a Seiko 0439-4009
elceedee
Post30 Jan 2013, 02:03
This Seiko 1977 0439-4009 came to me in a lot of seiko's, casio's and other digitals.
The watch was in very bad shape; many signs of usage, on crystal, bracelet and buckle. Beside that, the movement was switching on and of due to some corrosion/bad contacts.
The fact that this Seiko is one of the rare models with a plexi crystal made me decide to restore it (and off course the fact that i love this model!)
I started with servicing the movement (high quality, beautifull), it worked fine after that. Then the case, sandpapering, polishing etc. Eventually the scratched bracelet, i replaced the buckle with another one as the original was too heavy damaged.
I forgot to take 'before' pictures :roll: But i had a picture of the seller, i selected this watch in the picture to give you an idea;
Then the result
Re: Restauration of a Seiko 0439-4009
Post30 Jan 2013, 02:41
WOW Impressive work - it looks like new, great job 8-)
mikenj
Post30 Jan 2013, 04:51
You have given me hope for an 0439-5007 that is going to need work.
It is great to see how much life you can bring back to these watches.
Mike
Seiko&Casio Lcd's
Re: Restoration of a Seiko 0439-4009
Post31 Jan 2013, 00:52
Great job, seicitizitch.
I enjoyed looking at your restoration pictures. :-)
Post31 Jan 2013, 13:18
Well done friend....good job for sure! :-D
Post31 Jan 2013, 15:23
is it the same watch? Remarkable job :-D
DWT26
Post28 Feb 2013, 22:04
Fantastic turn around. Really impressed with the end product
retrowrist
Post01 Mar 2013, 08:37
seicitizitch,
I have one mthing to say about this job...Cleeeeeeeeean!!!! Wow! I wonder, does the crystal separate from the Bezel? Can you take the crystal out from this model? I would love to know what the process is, but I will understand if you keep it a secret.
Thank you for showing.
- Patrick
elceedee
Post01 Mar 2013, 12:52
Thanks for your positive reactions all :-)
@Patrick: actually this Seiko has one of the easiest crystals to remove. You need to remove the movement and the inner bezel round the lcd panel. After that you can push the crystal out of the case by simply pushing the crystal. Its a rounded plexi crystal with a gasket round the edge.
Goodluck!
