It is currently 02 Nov 2025, 08:15
Seiko G757 weak alarm
mikenj
Post30 Jan 2013, 16:14
I am looking for advice on how to troubleshoot and repair the alarm on my G757. The sound element came loose in the case and it seems to only produce a very faint sound. While active, it also appears that the alarm is drawing too much current which causes the display to fade.
Is there a good guide/thread somewhere on how to approach the repair of the alarm for these kinds of watches?
I have searched the archives and didn't find much though that may be to my poor search skills.
Thanks in advance.
Mike
Re: Seiko G757 weak alarm
Post30 Jan 2013, 21:49
hi Mike,
i presume you all ready had a look at the tech guide
http://www.digitalwatchlibrary.com/images/seiko_manuals/G757A.pdf
mikenj
Post31 Jan 2013, 01:16
Kasper,
Thanks -- No I hadn't. I will check out its recommendations.
Mike
mikenj
Post14 Mar 2013, 14:59
My son has been wearing this and I finally got a chance to check it out. It seems that whenever the alarm fires, the display dims as if there is a voltage drop. A fresh battery lasted 2 months in it when my son brought it back to me. I checked the voltage at the spring contact and I'm not really seeing any. The manual says to check resistance at the coil which I am reluctant to do as I have to disassemble the movement to get at it.
The piezo element has come unglued and doesn't look to be in great shape. There seems to be a small shiny spot on the movement side which may have aligned with the spring, but it is hard to tell.
So I am looking for advice on what steps/tests I can take before I start taking the movement apart.
Also, does anyone know if a replacement piezo element is available?
Mike
