It is currently 25 Aug 2026, 05:19
Seiko A039-5019 Disassembly: help please?
seikosha007
Post06 Apr 2013, 02:38
Hello folks,
My first post here. Thanks to Hanno for registering me.
So....I recently purchased this Seiko A039-5019 and I am setting out to disassemble it for a clean and service. My problem is I can't figure out how to remove the Caseband (see attached picture from the A039 Technical Manual and picture of watch itself) -- apparently there is a Seiko tool that can be used to open up the A029/A039 series Casebands, but obviously this would be hard to obtain. It's very easy to remove the caseback (it comes right off once you unscrew the battery compartment) but I can't figure out how to proceed further, and there aren't any obvious springs to press on.
I would be grateful if anyone could assist me. Thank you!
Yota
seikosha007
Re: Seiko A039-5019 Disassembly: help please?
Post06 Apr 2013, 03:07
As a follow up to my earlier post, I believe the Seiko tool for opening these watches was a "twin tooth opener for twin sprung slot Seikos" (information gleaned from another DWF post).
If someone knew of a way of disassembling the case without one of these tools, that would be great!
Yota
Post06 Apr 2013, 09:51
if i remember it correctly, the module just pops out. i see the case has a little bump at the other side of the pin..maybe that is holding it in place?
or wait...it has small springs at the top and bottom...so you have to push them in the get it out! look for the small gap on top in the case...its there so you can push the spring of the module to get it out.
update found a picture of mine
btw..welcome to the board from us all, we hope you enjoy your stay here.
Seiko&Casio Lcd's
Post06 Apr 2013, 12:25
Hi and welcome :Hi:
You can push in a spring (circle on the bottom of the picture) with a small screwdriver and then flip the screwdriver.
This goes for the bottom spring as well as the top spring.
Then the 2 halves come apart.
Seiko&Casio Lcd's
Post06 Apr 2013, 12:37
BTW
If you have it apart ,and you can't get the crown removed, just post a picture of the inside, then i can tell you what to do. ;-)
seikosha007
Post06 Apr 2013, 13:57
Thanks to Kasper and Seiko&Casio Lcd's for your suggestions and tips!
I have now successfully opened up the case. Now that I've had a look at it, I can see how the spring is designed. I did try pushing in the locations indicated before but I obviously didn't press hard enough (I was too scared of breaking something!). I'm glad to have sought the assistance of this forum.
Here are some photos and a close up of the case spring.
download/file.php?mode=view&id=1224
download/file.php?mode=view&id=1225
Thank you once again for your help -- I really appreciate it!
Seiko&Casio Lcd's
Post06 Apr 2013, 20:17
You're welcome mate :-D
It's a nice looking watch, was the original band with it ?
seikosha007
Post07 Apr 2013, 10:04
It came with a Seiko signed bracelet -- XNA130 -- which looks appropriate for the period but I don't think it's the original. Other sites list it as coming with the B316 bracelet.
Looks like a previous owner has done some case polishing to it, and a NOS crystal fitted as well. But it functions just fine, and I'm enjoying wearing it!
seikosha007
Post07 Apr 2013, 10:08
I took some more pictures of my A039-5019, so I thought I'd post them up!
Picture of the A039 module:
A039 LCD:
Seiko&Casio Lcd's
Post07 Apr 2013, 20:20
Thanks for posting.
Yes, the B316 is the original band that's correct.
I remember now, this module comes out easy, with some seiko's you have to push in a lever to free the crown and pull it out.
Not necessary with this model.
Return to Mechanical
