It is currently 30 Oct 2025, 14:30
Removing the module from a Seiko 0124-0049
albertofenini
Post24 Apr 2013, 21:36
ciao a tutti,
I'm in the progress of restoring a Seiko 0124 recently acquired.
It is in non working condition, and it was VERY dirty.
However, I have managed to open it, but I cannot remove the module.
I have been able to remove the stem, but it looks like there is nothing I can do to free
the module from the case and inspect the module condition.
I would like to see if apart from the LCD which is obviuosly broken there is something else ...
Any hint, will be greatly appreciated, I'm attaching some pictures, just in case ....
Thanks in advance Alberto
quietman
Re: Removing the module from a Seiko 0124-0049
Post24 Apr 2013, 22:59
Gotta rotate the white plastic ring one way of the other, can't remember exactly
albertofenini
Post24 Apr 2013, 23:36
it does swing in both ways, but very very little
and not enough to let the module slip out,
how much should it rotate ?
thanks alberto
quietman
Post25 Apr 2013, 00:13
Your last photo shows the ring in the locked position. From here rotate it anti-clockwise about 40degrees - you will see the three locking tabs in the white plastic ring 'appear' in the top left and two bottom corner cut-outs in the metal. Then you can remove the movement.
albertofenini
Post29 Apr 2013, 13:42
Thank you very much,
that worked out !
I'll take some pics of the module with the LCD removed later,
thanks again
take care Alberto
albertofenini
Re: restoring a Seiko 0124-0049 (UPDATE)
Post05 May 2013, 23:56
ciao a tutti,
thanks to Quietman I have been able to remove the module from the case.
There was some oxidation but nothing too bad and the module has been cleaned.
Now the question I have for the most expert people is :
before I invest some money in a new LCD panel, how can I test if the module is working ?
Is there any way to find out that the module is alive ?
Also, please look at the next message ...
Thanks again Alberto
albertofenini
Post06 May 2013, 00:03
One of the problem this watch had was the retaining system for the stem.
If you look at the two following picture you will notice that the
spring is complete e correctly mounted :
while in this picture :
the same spring is broken and partially still in the module,
but I need a replacement.
Seiko part # is 637-001 Stem Setting Spring, does anyone know where I can get one ?
Thanks again for your help and advices
Alberto
