It is currently 18 Sep 2026, 19:41
Hamilton display
jdavid
Hamilton display
Post05 Nov 2013, 13:47
Hi all this is my first time on this great web site,i have two questions first does anyone out there have a good working display for a hamilton qed they could sell me and second what size and diameter of O ring is used in the case seal.Many thanks Dave Owen in the UK.
Re: Hamilton display
Post05 Nov 2013, 22:22
You don't say what specifically what the display on your watch is doing (or not doing) that suggests it may need replacing. Some pics would help determine what's wrong (hopefully, it will turn out, you don't need a new display at all). Measurement of the O-ring groove is 37.5mm OD, 36mm ID.
jdavid
Post06 Nov 2013, 07:37
Hi Bruce thanks for the case seal info.The watch in question is a Hamilton QED one button type the display has one missing segment the upper left hand side,so i sent the watch to pulsar led time to test and he said it is the display that is faulty hence the need for a replacement.PS very impressed wiyh the quality of the case opening tool you sent me via ebay. :-D
Post06 Nov 2013, 08:04
Ah...always good to hear from a satisfied customer!
If there is just a single missing segment in a digit (and the same segments in the other digits DO light up, then what you have is a broken wire bond, and, since the display is epoxy-encapsulated, that's not repairable. The trick is to pop the original display off the circuit board, and, using silver epoxy, re-attach a replacement. I've done a number of these repairs (in fact, just finished one for a collector in the Bay area), so, I know it's possible, and are very reliable, if carefully done. I'm surprised PLT didn't have a spare display on hand, since he's building replacement modules that use the original Litronix and Monsanto displays. I'd be willing to take a crack at fixing your module, if you don't mind sending it to California. On the case wrenches, I use these on my own watches, so I make no compromises on the consistency and accuracy of the machine work (my father was from Switzerland, so there's a certain family tradition of quality to uphold).
jdavid
Post06 Nov 2013, 13:38
Hi Bruce thanks for the kind offer what sort of cost would the repair be if it works.
Cheers Dave.
Post06 Nov 2013, 20:57
I charged $60 on this last one (I charge for a repair ONLY if it's successful, otherwise, you're out only the round-trip postage). It's worth the attempt to restore an original module; that way, your watch retains virtually all its' collectible value.
jdavid
Post07 Nov 2013, 09:17
Hi Bruce $60 is fine,i havn't got the watch back from PLT yet as he is also looking at a casio for me.If you could email me your postal and email addresses i will send the module as soon as i get it back and will email to advise it's on it's way cheers Dave. :-D
