It is currently 07 Oct 2025, 12:55
BULOVA 'BIG BLOCK'
peter.g
BULOVA 'BIG BLOCK'
Post22 Jan 2014, 18:34
My chunky 1974 Bulova.
Re: BULOVA 'BIG BLOCK'
Post22 Jan 2014, 22:30
Cool watch 8-) Super photo! Thanks for sharing :-D
Post22 Jan 2014, 23:01
The pimp watch of the seventies :-D great shot...great watch :dwf:
LEDman793
Post29 Jan 2014, 05:29
What module does the Big Block use? :?: :-D
My life would never be the same without the soft warm glow of happily shining LEDs!
Post29 Jan 2014, 16:01
LEDman793 wrote:What module does the Big Block use? :?: :-D
It is a re-branded Hughes 29mm module with the addition of an extra contact to make it function with the 3 o'clock position push/pull command button.
Post29 Jan 2014, 16:07
BTW: A standard one button Hughes 29mm module can be easily modified to work in the 'Big Block', see this thread here for details viewtopic.php?f=64&t=3287&p=19847&hilit=bulova+convert#p19847
Phasar66
Post29 Jan 2014, 18:48
bucko170 wrote:BTW: A standard one button Hughes 29mm module can be easily modified to work in the 'Big Block', see this thread here for details viewtopic.php?f=64&t=3287&p=19847&hilit=bulova+convert#p19847
You are right and that's the way it should be done in the first place if they had the later module. I believe all this Big-blocks came with the early Hughes dot display module which is prone
to wire-bond problems and missing segments, that combine with awkward push pull crown command that is very sensitive to misalignment . not wonder you find so many not working or acting up.
lucky for Us the brains of the DWF almost always came with an answer. Don't You love the
