It is currently 07 Oct 2025, 19:45
omega memomaster lcd?? update arrived!!
Re: omega memomaster lcd?? update arrived!!
Post17 Feb 2014, 21:59
I am pretty sure it fits in the groove, the push into the container squeezing the clip so that it friction fits in the container.
Cheers
Ps. If it works now then great, problem is it might rotate while in the container. Maybe slip a small battery gasket in the groove and push it into the container.
Post17 Feb 2014, 22:26
Super cool it works :) Unfortunately, my girlfriend didn't want to wear the Tissot F1 :( I wish it was bigger...
Post17 Feb 2014, 22:38
its almost impossible to fit it in the container with the ring round the piezo. I all ready lost 2 nails :-D
Post18 Feb 2014, 02:59
If it works great! Maybe try the battery gasket o-ring trick. Fit it in the groove tightly but large enough in diameter that it is larger then the holding ca. This will prevent it from moving around and the contacts shifting causing a short.
Geoff
Post19 Feb 2014, 00:23
Actually i got the same watch, but in Stainless Steel with matching Stainless Steel bracelet. Amazing watch, too bad it is so small, it would be a great mens watch if it was like 1.5 - 2 x larger.
Previous
Return to Ebay and Other
