It is currently 02 Nov 2025, 04:55
Seiko 0439-5009 question
elceedee
Post13 May 2014, 21:34
Hey guys,
I haven't seen this way of securing the crystal on a 0439 before.
The ring covering glass and inner bezel, is it loose or pressed in. Can I remove it by pressing a screwdriver in the upper gap?
Re: Seiko 0439-5009 question
Post14 May 2014, 11:53
http://www.newdwf.com/viewtopic.php?f=65&t=7006
get the pushers out, the glass is pushed to the front with a soft black rim between it. I cannot remember if the backplate is hold in place with the pushers or not. I broke the glass and suddenly i had the backplate in my hand so :-D
check my link above
elceedee
Post15 May 2014, 18:43
Thanks for the clear pictures Kasper!
Looking at them I expect to have the crystal come out too when I remove the ring, so I will keep it put and work on it this way. These crystals are a pain to attach properly...
Return to Mechanical
