It is currently 24 Jun 2026, 18:11
Seiko 0439 5007 display is flashing/blinking
roland
Post06 Nov 2014, 18:21
the display of my 0439 has recently started flashing. I already looked at the "technical guide" but this error wasn't mentioned.
I tryed a new battery and it's still blinking. Then I disassembled the panel, cleaned the contacts etc...
What can it be? Does anybody have an idea? Maye even to fix it?
I uploaded a video so you can see for yourselfs...
http://youtu.be/GbrgOdK2SD4
Re: Seiko 0439 5007 display is flashing/blinking
Post07 Nov 2014, 18:24
Did you try to leave the battery out for a week, looks like it stays in settings mode.
Post08 Nov 2014, 01:23
I agree with Kaspar. I'd also try:
Check the battery with a voltmeter (new batteries aren't always "new")
Check all of the buttons are making correct "on" "off" contact with the module (if ones "on" all the time it will mess things up - likewise if the setting button isn't making contact).
Check for oxidation on the module shorting out the setting circuit
Lovely watch - hope you can get it sorted.
Users browsing this forum: No registered users and 44 guests
