It is currently 02 Nov 2025, 04:47
Help with a 1972 Girard-Perregaux Quartz with date mechanism
gallas27
Post17 Jan 2015, 18:38
Hi guys,
I want to ask you a question about a big problem affecting my 1972 Girard-Perregaux Quartz with 351 caliber.
Basically the date doesn't change completely, but only half, every day :bang:. I have to make it change completely by ticking the case with my nail....
So here's my question: do you think the date mechanism is interchangeable with the one of a 352 or 353 caliber?
I read this page:
http://www.ranfft.de/cgi-bin/bidfun-db. ... regaux_351
But I don't understand if it is interchangeable or not ....
Please, help me !
Re: Help with a 1972 Girard-Perregaux Quartz with date mecha
Post20 Jan 2015, 21:02
If I read it correctly, everything is interchangeable, EXCEPT the date mechanism.
But your mechanism basically work, you "only" have to tap the case ;) It might be worthwhile to investigate the problem. The date ring has to move without any resistance, and is apparently spring loaded.
Check the mechanism for any dirt or excessive oiling. I "repaired" the day-date mechanism of my Omega Speedsonic by carefully removing all the oil from the day and day ring. (someone really overdid it with the oil) I doubt it needed oil at all.
Check the "springloaded action" of the mechanism, maybe a little bit careful bending of a spring is enough?
And show lots of pictures of this amazing watch :)
gallas27
Post23 Jan 2015, 19:20
dutchsiberia wrote:If I read it correctly, everything is interchangeable, EXCEPT the date mechanism.
Yeah, sometimes it works properly sometimes it works "partly" but, at this point, it's better for me not to spend other money on this watch or, worse, buy a non-function GP on Ebay in order to restore mine.
Especially after what you said (find a 351 movement it's almost impossible and I don't have the guarantee that the date mechanism works...).
Thanks and for the pictures...just wait that a nice and sunny day let me to shoot some photos :-D!!
Post24 Jan 2015, 15:16
I believe it is the same setup.
Compare with the 352 and 353 on my website:
http://www.crazywatches.pl/girard-perre ... uartz-1972
Return to Mechanical
