It is currently 02 Nov 2025, 04:48
Without caseback: works, with caseback: doesn't!
gallas27
Post15 Jun 2015, 14:32
Hi guys,
I have this kind of strange problem with my Mido CD Quartz, with ESA 9315 module.
The original module was eaten by the acid, so I bought a NOS ESA 9315 (same as the original one).
The module works fine, all the functions work properly, but when I place the caseback and press the buttons, they don't work at all :bang:.
What kind of problem is this? First time in my life I see something strange like this....
Thanks ;-)
Re: Without caseback: works, with caseback: doesn't!
Post19 Jun 2015, 18:03
Something making an unwanted connection with the case back and shorting out?
Post20 Jun 2015, 09:33
Put some tape on the inside of the caseback as a test.
gallas27
Post21 Jun 2015, 22:00
charger105 wrote:Put some tape on the inside of the caseback as a test.
It worked out! :-D!
Now another question: WHY :scratch:????
Post22 Jun 2015, 08:20
It worked out! :-D!
Unless it's some strange coincidence it must be that something is or was making an unwanted contact with the case back. Could the watch be missing its original plastic isolating cover between the case back and the module?
Glad to hear that you go it working again. :-D
gallas27
Post22 Jun 2015, 22:35
It seems that works only with the tape inside. That's not fine :-?.
There was no plastic before (the module was the same, just marked Mido instead ESA), so I don't know why it happens....
Post23 Jun 2015, 21:13
Why not upload a photo - maybe someone will be able to spot something you are missing :?:
gallas27
Post28 Jun 2015, 19:32
I know it's not the best...I hope you can see :-D
Post28 Jun 2015, 20:01
Im not sure its the same for all these 9315 modules. The screws at 9 o clock an three o clock usually have a small piece of metal to hold the movement in place inside the case, yours doesnt have these. Maybe this is letting the module short on the case back.
regards
Post29 Jun 2015, 09:53
Try putting small pieces of tape in different positions on the caseback.
You'll eventually pinpoint where the short is :mega:
gallas27
Post29 Jun 2015, 14:25
DWL wrote:Im not sure its the same for all these 9315 modules. The screws at 9 o clock an three o clock usually have a small piece of metal to hold the movement in place inside the case, yours doesnt have these. Maybe this is letting the module short on the case back.
regards
Wow, I think you have just discovered the cause of the problem!!
Actually, watching some pictures on Google, every ESA 9315 have those small pieces of metal....now the question is: where can I found them :mega:?
Post29 Jun 2015, 20:34
gallas27 wrote:.....Actually, watching some pictures on Google, every ESA 9315 have those small pieces of metal....now the question is: where can I found them :mega:?
If nothing else it shouldn't be too difficult to make some by sniping a bit out of an aluminium drinks can and shaping to size.
Post14 Oct 2015, 13:10
Hey Ale...is the watch still working fine now? ;-)
