It is currently 07 Oct 2025, 12:59
Wanted: Seiko C359 battery hatch
nick0123
Post05 Dec 2015, 11:06
I'm looking for a battery cover for Seiko C359 calculator watch, example pic below.
I have a few other (used) Seiko battery hatches if you are looking for something in particular?
jagmad
Re: Wanted: Seiko C359 battery hatch
Post07 Dec 2015, 21:04
Pretty sure I have one somewhere?
Do you have any seals for the hatch?
I need a couple. :Prost:
B. YOU NEED TO SWITCH IT ON.
nick0123
Post10 Dec 2015, 11:39
Unfortunately not - and that's how I lost the battery cover on my C359 !
The battery gasket had become rock solid and wouldn't turn at all so I had to take the watch apart at the ends and get the battery cover off with my fingers from inside and out, which was a bit of a struggle.
Removed the munted gasket and replaced the battery cover meaning to make or buy a new one but rushed out the door a few hours later, grabbed the watch to wear, and when I took it off when I got back, yup, battery cover gone.
Such an idiot - that's pretty much watch etiquette 101 - so I've got the battery held in with aluminium foil tape which does the job and doesn't look half as bad as it sounds, but is not a permanent fix at all. I'll be making sure the new cover doesn't come off if I ever get another!!
jagmad
Post10 Dec 2015, 19:55
Oh dear, the same happened to me but luckily I spotted it. ~:(
I haven't worn it since and won't until I get some O rings/seals for it.
Perhaps someone on here might be able to point us in the right direction. :call:
Mick showed me some on ebay but they were all to big.
I'll have another scout.
nick0123
Post10 Dec 2015, 20:25
Worst case you could probably make your own with some (very) thin rubber and a couple of circular punches the right diameter. Won't be as good as the original but should come close (and should stop it falling off).
Thanks for looking, I appreciate it.
jagmad
Post14 Dec 2015, 12:51
PM sent Nick. ;-)
werker28
Post13 Oct 2016, 04:54
I am also looking for a battery cover. did you ever find one for your watch?
thanks.
nick0123
Post18 Oct 2016, 10:34
I did; there were a couple of blokes on here who had them, so hopefully you'll also be lucky.
werker28
Post30 Nov 2016, 05:54
i managed to find a whole watch, in pieces, but i got the battery cover. i love the watch!
