It is currently 02 Nov 2026, 02:06
Unusual behavior in P4
Erinn
Post03 Mar 2017, 01:01
I just got a P4 Classic, with Autoset feature, and I noticed that after I set the desired time the display that I want, the display goes black after a length of time (30 seconds?) but there appears a steady "-" (minus sign, one segment lit) at the last digit. Just one bar segment lit, the one in the middle, resembling a minus sign. It stays on indefinitely until I press button.
When I push button to synchronize with external time reference the display lights up with the time, and is normal again.
I am new to collecting these (so far have about 10). This "minus sign" is new to me.
Everything else is normal. I am testing the timekeeping.
Is this "minus sign" a normal feature on some Autoset modules? Or could this be an early sign of module failure?
I think it is anomaly, but maybe harmless.
Re: Unusual behavior in P4
Post03 Mar 2017, 01:46
I just checked a few of my P4s, and none of them show this behavior. After setting the display normally goes dark immediately (magnet-set version) or after 5 seconds (Auto-Set version). So, I would have to consider what your watch is doing, a new symptom of aging in Time Computer electronics.
As a side note...on the 800 module (Auto-Set module used in the Men's Sport and Touch-Command Dress), if the minutes are set, a single blinking colon dot remains on after the display blanks, presumably as a reminder that the watch was set, and needs to be re-started for normal timekeeping.
Erinn
Post03 Mar 2017, 04:13
Thank you Bruce, for your reply.
It appears to exhibit this behavior consistently, which I suppose is a good thing.
And I was wrong about the 30-second delay; the "minus sign" kicks in exactly at 5 seconds.
Timekeeping appears to be perfect thus far. (I use www.time.is as a reference.)
So, I will not lose any sleep over it.
But if it is an early sign of IC failure, I may consider sending it to HAnno for an SASM "transplant".
