It is currently 29 Jul 2026, 21:16
replated time computer
Post23 May 2007, 19:23
i bought a battered white gold TC1 for the module a while back. The case was dented on the corners, the plate had worn through, various dings and scratches etc.It's been floating around in my "spares" box ever since. I set about it with some 360 grade wet and dry and with patience removed most of the damage- but the goldfilled plating was by then -wrecked, with the base metal (brass ??) showing through in various places. I sent it away to be replated and heres the result- not perfect but certainly wearable Any opinions :?:
re: replated time computer
Post23 May 2007, 20:00
You left out two critical bits of information! Where was this done, and what did it cost?
Post23 May 2007, 20:19
Hi Bruce, the case was plated first with Pallnic to give it a good base cover of the correct colour then overplated in rhodium (as is all white gold today). This finish in no way compares to the robustness of the original Omega goldfill but has in this case saved an unwearable watch- surely a good thing :D the colour is lighter than the Omega original and to give you an idea, is actually now a very close match to the s/steel bracelet in colour. I sent the plating company a couple of brushed links as a sample and a couple of pics of an original, they then gave it the "satin" brushed finish. And finally to answer your question :roll: Company- F Sinclair Ltd in the UK- Cost- £40+£6carr+ vat total £54.05 about $110 US
Return to Omega and GP
