macfranky wrote:Goodie. The watch is set; it is the 'auto-set'. allthough I can't seem to find the AM/PM feature. (Tried the instructions from OldPulsars.) It actually sets with both a magnet or the buttons. Thank you guys for the response. Much apreciated.
MacF
MaxF: As the date was moving past, the colon was first showing up in the upper position, then the bottom position, then on to the next day with it in the upper position. The upper position is AM, lower is PM. You just need to stop it at the correct point. It
can be activated by a magnet that gets close enough to either top or bottom of the watch, since your autoset DOES have a magnetic reed switch at each button, just not at the setter indents. Get used to the buttons...no point in banging up the back tapping a magnet on it.
Plus, many magnets that are stong enough to activate the reeds from the back will activate both reeds, just causing confusion in the setting process. Go back to
www.oldpulsars.com - he has better instructions on another page, the ones in the link are scans from a manuel. And we all know how manuels don't always underscore the subtle points.
http://www.retroleds.com -
Sales of vintage LED, LCD, analog watches,
parts and gadgets -
repair tutorials & tips
