It is currently 20 Oct 2025, 01:54
Brand new modified solar cells.
Synchroserious
Post27 Nov 2008, 18:41
New solar cells available for enthusiests trying to build their own.
These are better quality(less brittle) Solar Cells than that used in the 70,s.I have placed teflon coated electrical tape on the bottom.
Please specify if you need one for MK I , MK II which has a different wire location in the (-) back.If it is for MK III(chip is rectangular) you may need to send me a photo because some of those PCB's require the same location as MK I and MK II. If it is for a MK IV(chip is square) the negative wire will be installed accordingly.
Cost, $25.00 + $2-$15 shipping depending on location and choice of shipping.
The smallest spool of the wire on line is $25.00 and it is not an easy solder job.Takes me 20-30 min to swap wires.
If you want one without the wire upgrade and wish to install your own wire the SC,s are only $12.50
