Hello, I just bought a Bowmar LED watch which is the same one as shown in the digital marketplace by London_funk (LED-Bowmar) on June 2, 2009 (also shown in the photos section under Led Bowmar by Collin Thomas). I'm trying to find out what function is suppose to be displayed when you press the bottom button and how you set this function. When I press down this button the numbers 1 through 31 can be set to the left of the two dots and this number seems never to change after being set while the numbers to the right of the two dots show the seconds that can be set. If I continue to hold down the button the seconds display is only shown. The top button correctly displays the time in an AM/PM format and can be correctly set. I think my watch is not correctly displaying the function when I press once the bottom button and I'm trying to find out as fast as possible if this is true as I would then return the watch for a refund. Do you know the answer to this question and if not can you forward this question to someone who may know this answer. Thank you in advance for your help.
