It is currently 25 Apr 2026, 10:46
Kevin's first attempt at battery changing and module opening
redcar66
: Kevin's first attempt at battery changing and module openi
Post21 Feb 2010, 05:33
Re: : Kevin's first attempt at battery changing and module o
Post21 Feb 2010, 17:54
Post22 Feb 2010, 00:29
redcar, you should go to radio shack or a similar store and get a 3v powerpack and some smooth jaw alligator clips. i have 2. 1 for AA cells and 1 for C cells. it is a lot easier to test out that way and the voltage will be sufficient for a bright display. jeff, the stuff came yesterday but i missed the m/m. need to go to p/o tomorrow. :-( peter
redcar66
Post22 Feb 2010, 00:36
Post06 Mar 2010, 04:15
redcar66
Post06 Mar 2010, 05:45
Post06 Mar 2010, 08:33
Impressive. The most transistors I have ever replaced on a Pulsar module is three. Seems there's almost no limit to what you can accomplish with a fine-point soldering iron and a steady hand... :eek:
Post07 Mar 2010, 02:14
Very impressive work there JThomas - hats off to you! :o
Post14 Mar 2010, 04:13
Previous
