It is currently 20 Jun 2026, 13:29
Decimal Hour Time stopwatch?
spinchb
Post07 Sep 2010, 17:08
Hi All,
I was wondering if any of you know what a stop watch in decimal hour time would be used for? Someone gave me one 20 years ago and told me next time I saw him he'd tell me what it's for. I never saw him again! I have my theory that it's for timing auto rally races and converting easily to mph or km/h based on the decimal time. Anyone know for sure?
Thanks!
Shawn
: Decimal Hour Time stopwatch?
Post07 Sep 2010, 20:02
This sounds interesting, can you post a picture... :-D
Post07 Sep 2010, 23:27
No idea, never seen one.
Sounds interesting.
Picture?
Are you saying this stopwatch displays e.g. 1.50833 for 1h 30min 30sec?
spinchb
Post08 Sep 2010, 06:41
Hi All,
Here's a link to a photo of it.
http://yfrog.com/0tzivydecimalhourj
Yeah, the time works as you suggest 30 min is .5 hour 15 min is .25, etc. It's a curious item!
Shawn
Post08 Sep 2010, 09:55
It's a rally stopwatch designed to make the use of a Curta mechanical calculator much easier (only a single H:M:S conversion rather than two in figuring out the problem)- a lot rarer than Curtas and probably very desirable to vintage rally enthusiasts.
Re: : Decimal Hour Time stopwatch?
Post08 Sep 2010, 10:06
spinchb wrote:Hi All,
Shawn
Oops, I believed it was a digital stopwatch, but it's analogue :-(
Do I understand correctly: the large scale is 0.010h (36sec) and the small scale goes up to 0.30h (18min)?
So this is not just a differently printed dial, but the movement too must be different from a "normal" stopwatch.
For convenience: direct link to photo
Post08 Sep 2010, 14:05
@ OldTom: Is this true (designed for rallye and Curta), or just a guess, or even a joke?
spinchb
Post09 Sep 2010, 05:18
I think OldTom is right. I did a little math to test the idea. :-)
For example:
If you're driving 3 km and it takes you 78 seconds, to get km/h:
(3 km/78 sec) X 3600 (this is the seconds in an hour)
= 138 km/h
In decimal time:
3 km/.02167 = 138 km/h
One calculation, all you need is the distance (odometer) and decimal time and a Curta Calulator and you know your average speed for a distance.
Shawn
Post09 Sep 2010, 18:45
So if I want average speed in km/h, all I have to do is divide driven distance (in km) by taken time (in h)? That's ingenious :idea: ! Does this also work with miles?
AFAIK the Curta isn't exactly fast or easy to operate at divisions. A slide rule would be faster. But in both cases it's easier if the stopwatch tells you the time directly in decimal h instead of h:m:s.
spinchb
Post10 Sep 2010, 04:01
Yup, works with miles. Whatever your distance measurement is.
Shawn
