It is currently 26 Oct 2026, 00:58
Mens Dress model
Shiniquiet
Mens Dress model
Post25 Mar 2011, 22:58
I recenty acquired what I believe is a men's dress model. It didn't fire up so I opened the back and replaced what must have been the original SR43SW batteries with two 301's. It still didn't fire up, not to mention that I can't get the back screwed on - of course, if I had the right size pulsar tool that would help. Anyway, I guess my question is, Does the back need to be screwed in correctly for the thing to work? Any insight into how I might get this working (last resort is that I send it off for repair) would be helpful.
joer10
: Mens Dress model
Post26 Mar 2011, 01:39
try 386 size cells sir
Shiniquiet
: Mens Dress model
Post26 Mar 2011, 12:42
Just curious, but what will the 386's do that the 301's don't? Is it a size thing or what?
joer10
: Mens Dress model
Post26 Mar 2011, 12:45
yes right size of cells 301 is not right size
Shiniquiet
: Mens Dress model
Post26 Mar 2011, 22:39
Aw,nuts! Now that I have 20 bucks tied up in batteries I'm sad to report that they didn't do the trick. So, before I send this little puppy off, if anyone has another idea that I could try, I'd be grateful to heart it.
: Mens Dress model
Post27 Mar 2011, 12:38
The case back doesn't need to be screwed down but it does need to be touching the batteries and the case of watch to complete the power circuit for it to function.
Idea's
Make sure you have the batteries the right way up.
Clean the contact points with a fibre tipped pen and some rubbing alcohol both on the module and the case back.
Try both buttons and also an external magnet to see if the display activates.
Be careful not to cross thread the screw ring.
If nothing works consider repair or get in touch with Greg Ratcliff at gsratman1@embarqmail.com to buy a NOS replacement module.
Good luck.
Shiniquiet
: Mens Dress model
Post28 Mar 2011, 15:44
Thanks for the suggestions. I really appreciate the assistance. Hopefully, within the next couple of days I can give them a try. I'll let you know how it turns out.
Shiniquiet
: Mens Dress model
Post29 Mar 2011, 02:17
Tried the magnet trick a little bit ago using a couple different magnets, but to no avail. I'll try the alcochol method in a day or two but, frankly, I'm not having much hope.
Users browsing this forum: Google [Bot] and 20 guests
