It is currently 02 Mar 2026, 11:20
Citizen calculator watch testing components advice
Post02 May 2011, 15:26
I have a citizen calculator watch that I stripped down to replace the crystal. It was working when I stripped it but when I put the case together I heard a crack and the lcd digits just faded away. Initially I thought I had cracked the board but after looking through the glass I can find no damage.
I know you guys are more used to LEDs but some advice on testing components on the board would be appreciated. I have a digital multimeter for testing.
When put back together only the the light now works.
Any help really appreciated as at the moment im gutted.
regards
: Citizen calculator watch testing components advice
Post03 May 2011, 14:28
Hi Adam.
I've never worked on one of these before, but if you heard a crack, it should be possible to see where it is.
Have you tried holding the board up to the light ?
What about the LCD display ? Perhaps the display has cracked (at the connection edge/s, where no 'bleed' would occur).
Post05 May 2011, 17:18
Thanks Andrew
Nothing I could see on either of those. I thought if I could check anything on the board I might have damaged, that I might be able to replace. I'm still gutted, i'd cleaned everything, stripped the buttons, dismantled the keyboard and even polished the front steel. I have now put all back together and put it in a drawer hoping it would come back to life, but nothing yet.
Post10 May 2011, 16:43
I'm guessing you cracked the matrix somehow....bleed is so unpredictable. A lot of LCDs will sit there and not bleed at all if they are cracked in one motion - the glass is tightly together(quality build), the LC "blood" is intact and the air is not exactly forcing it's way in. A lot of bleed starts at an edge or in the center(in those early LCDs that were filled from a center point and have a plug on the back of the matrix). I'm thinking that bleed is more a function of the laminations separating and creating a vacuum which is then filled by either air or LC. Of course in the case of extreme heat(LCD on dash of hot car :x ), all bets are off on how a display might decide to prostate itself before the final act.
