It is currently 02 Mar 2026, 10:11
Uranus Setting?
Uranus Setting?
Post21 Jun 2011, 19:04
I have a Uranus LED the same shape as this one but with one command at the 2 o'clock position and one command at the 4 o'clock position with a single set button at the 3 o'clock position, it is working and keeping time but I can only get the minutes to set, is there a special method to set the hours and date or is it faulty as I suspect?
: Uranus Setting?
Post23 Jun 2011, 02:32
UPDATE: The module defaults to midnight so I decided to remove the batteries at this time to get it to display the correct time, however once I had reset it back to default I was able to set the hour, date and minute without a problem :roll: I did notice that the module only has very thin contacts, prongs of wire rather than flat copper plates, so I suspect that I was not being firm enough with the command buttons the first time around. :oops:
Anyone know what frequency the QC is on this watch, I think I recall reading that it different to the usual 32,768 Hz and the Hughes 786,432 Hz?
Re: : Uranus Setting?
Post23 Jun 2011, 05:33
bucko170 wrote:[
Mick, you are partially right about the frequency. Some of those used the 32,768 and indicate the same in the literature - I think this is mainly their last modules, with the very conventional setter a 3, command at 1 o'clock.
Those early ones with the double command buttons - I've personally never had any luck with a crystal swap on those and can't offer actual assistance. It would be great if someone has an original manual for an early one that indicates the frequency. I looked at the two manuals I have, and neither indicates the frequency.. :x
: Uranus Setting?
Post23 Jun 2011, 06:01
Thanks Ed, I had a scoot around and found where I had remembered the info regarding the QC frequency it was from Piotr's website, he has an Elgin American Minicom containing an identical module to the Uranus one that I described and accordingly it has the frequency of 30.720Hz.......I'm guessing that's not going to be one that is still produced?
The glass crystal is chipped on the watch that I have if anyone happens to have a replacement going spare please let me know.
