It is currently 07 Oct 2025, 15:24
Frontier Modules
Frontier Modules
Post24 Sep 2011, 19:53
I've been trying to locate a Frontier module, preferably a 1602 with the sparkly dot style display, but a 1603 would be ok also.
Does anyone have an extensive list of the watches that used the Frontier modules? For a start, we have:
1) Hamilton QED II
2) Omega Constellation
3) Frontier branded LED watches
4) AMI
Anyone know what others had Frontier inside?
Ade51
: Frontier Modules
Post25 Sep 2011, 23:54
Just seen an Acousticon model just sell on EBay which claims to have a Frontier module.
Re: Frontier Modules
Post26 Sep 2011, 02:34
abem wrote:I've been trying to locate a Frontier module, preferably a 1602 with the sparkly dot style display, but a 1603 would be ok also.
1) Hamilton QED II
4) AMI
But you understand you can't just drop #1 or 2 into cases such as #3 &4, or visa-versa? The button travel distances and the diameters of the movement bodies are a few 1/10 of a mm. different, and the normal Frontier modules are 1.5-2.5 mm thicker, depending on the Frontier movement at issue. The Hamilton Omega movements are all about the same, 6 mm. * There are some HAmilton movements from the very end of the era, that are different and not Frontier made - blue face, clear body...won't workwell in anything but certain Hamilton cases, and you can't swap the circuit board out.
5)Mercury Time, very often.
: Frontier Modules
Post26 Sep 2011, 03:12
Ed,
Could you use the plastic carrier from a Hamilton or Omega Frontier module together with a new Frontier circuit board and display from another module?
Re: : Frontier Modules
Post26 Sep 2011, 03:46
abem wrote:Ed,
Exactly - I have explained this before,take a search. The only problem is the trimmer usually. The Hamilton/Omega used a smaller diameter trimmer. You have to shave a little plastic out inside. Super GLue Control Gel...small dots at a few spots along the lip. THey never snap together that tight any more. ;-)
http://www.dwf.nu/viewtopic.php?p=23197 I searched the site using "frontier circuit board", 3rd result. :-)
