It is currently 08 Oct 2025, 00:09
Texas instruments led model 402
Post14 Mar 2012, 22:13
My first led watch that "just works". :-D
When I got it the module looked clean, and fired up with batteries installed. I only cleaned the contacts to make the buttons more responsive.
It's a model 402 :-)
Re: Texas instruments led model 402
Post15 Mar 2012, 08:31
Another led watch saved, and it´s not a Pulsar. The TI watches seem to be good quality timepieces regarding their price. Compare it with modules from Hughes Aircraft and these seem to fail more often.
Post19 Mar 2012, 16:36
I'll have to disagree with you on the TI failure rate (you sort of zigged and then zagged). The TI's have an extremely low failure rate, imo lower than the Hughes by a small margin. They (TI) are very well sealed. The real problem with a TI is that the button contacts are thin, flimsy, easily bent little pieces of "stuff". And of course, a fair number are sold as none working by people who don't understand that most TI movements don't start actually running and moving forward in time until you have gone through the setting process once. Like the Litronix, TI wanted to be able to ship with batteries in, yet not have the batteries getting drained. The show time when you press the command, but the clock isn't running until it has been set. :lol: I've bought dozens of both from people claimed "it shows the time but the time doesn't change." :twisted:
Post20 Mar 2012, 09:27
That´s what I wanted to say. With "these" I meant the modules of Hughes which I don´t like at all. The TIs are quite good, although some watches were available for less the 20$.
